AdvancedTom
Multiple builds with different resource files in one project
Hello, experts,
I need some help with my project.
Following situation:
I have a project and I want to create multiple builds with different resource files for each build.
Is this possible with Advanced Installer?
I have tried to create build events to copy files, but that doesn't work for me because the specific file I want to change for each build can be installed in different paths.
The path for the file I want to change can be adjusted during setup, so it is not possible to copy the file to a static folder/path.
I tried to use a variable in the argument field of a build event, but that doesn't work.
I created a search property to check the path from the registry. This search works because a registry entry for the path will created during setup:
But the result of the variable remains empty when I use the variable for a build event or an installation parameter:
What am I doing wrong?
I hope I could explain my problem and you can help.
Thanks a lot for everything.
Greetings
tom
Re: Multiple builds with different resource files in one project
Hi Tom,
I replied you on "One project with different resource files for different builds" forum thread.
AdvancedTom
Thank you for your competent help. Excellent!
viewtopic.php?f=2&t=40489
You are always welcome, Tom.
We're glad you got this working.
