honzajic
Installer high DPI issue
I would like to raise an issue.
I upgraded from version 15.9 to version 16.2 and I have found a bug in how QuickSelectionTree is rendered on HiDPI screens.
This can be partially mitigated by setting Overriding DPI... in Compatibility tab on installer exe. But then this control looks blurry.
So not much a workaround.
Version 15.9:
Version 159.png (45.78 KiB) Viewed 4657 times
Version 16.2:
Version 162.png (59.78 KiB) Viewed 4657 times
Thank you for your reply.
Kind regards,
Honza
Re: Installer high DPI issue
Hello Honza,
I have forwarded this issue to our development team and we will further investigate it. Thank you for bringing this to our attention.
As soon as we will find what causes this and fix it, I will update this thread.
Unfortunately, I can not give you any estimation on when this will be ready. Thank you for your understanding.
This was fixed in version 16.3 of Advanced Installer released on September 4th, 2019.
