sschaeffer
(15.8) "Visual Studio 2015 Shell" installation when building a project
we're having trouble with one of our setups on a developer's computer. Namely, when building the project a "Visual Studio 2015 Shell (Isolated)" is installed (~ 30min installation time). This breaks off with the message "install server not responding" and the build continues.
Unfortunately, this behavior occurs with every build execution of this project.
Can you help me with this?
Version: Advanced Installer 15.8
Thanks.
Best Regards
Simon
Clipboard - September 4, 2019 2_35 PM.png (26.23 KiB) Viewed 2358 times
Clipboard - September 4, 2019 2_40 PM.png (6.02 KiB) Viewed 2358 times
Re: (15.8) "Visual Studio 2015 Shell" installation when building a project
Can you try the solution exposed in our "Build hanging with merge modules" thread and see if this works for you?
