In order to disable the summary window, you can launch the updater.exe using the /silentall command. This way, the Updater will search silently for updates and automatically install all updates.
Additionally, you can disable the update summary by going to "Updater" page --> under "Update Behavior" and select the "Check and automatically install" option. However, please keep in mind that this will disable the summary for all UI levels, not only for the silent one.
