Collins
Server-side Serial Number Validation With SQL
When the PHP scripts are updated to work with the latest version of PHP, could you also include scripts that will work with SQL Server and not just MySQL.
Re: Server-side Serial Number Validation With SQL
Hello Collins,
To be fully honest with you, I am not quite sure I understand what your request is here. Could you please give me some more details about the scenario?
Are you referring to our How do I configure server-side serial number validation? article? Do you need a sample script for SQL Server?
Collins
Catalin wrote: Mon Sep 16, 2019 1:53 pm Hello Collins,
Yes, a sample script for SQL server for that article.
Hello Collins,
I have added your request on our TODO list. However, as for this moment, this has a low priority as there were not many requests on this.
I will update this thread as soon as this sample will be added.
Collins
Any updates on this? Also, were the php scripts updated to support version 7 yet?
Unfortunately, the script has not yet been updated.
I have increased the task's priority and hopefully we will update this in the near future.
Collins
Any updates on this? It would be very useful if this functionality didn't rely on PHP.
Unfortunately, this has not yet been developed (the article/sample).
I will try to have a look over this the next week myself, hopefully I will be able to put up an article about this topic (this is currently assigned to a developer).
Writing such an article requires a lot of research, though, therefore this might take a little bit more time as compared to a developer creating the sample.
Collins
Catalin wrote: Fri Mar 26, 2021 5:22 pm Hello,
Thank you, this will be very useful for production use.
Even though this took a little bit more than I expected (a lot of research and testing had to be done), here is the promised article:
Server-side serial number validation with MSSQL and PHP
I really hope you and (hopefully) other users facing a similar scenario will find this useful! :)
Collins
Catalin wrote: Mon Apr 05, 2021 8:48 pm Hello,
That is awesome, thank you very much. I will take a look and implement it on our end and let you know if there are any issues.
You are always welcome!
I really hope you will find it helpful.
Return to “Feature Requests”
