Jacob Darka
Features and Quick Selection Tree
Hello!
I want to edit how the quick selection tree works, I have 3 features, and I want it to work like:
the default will be that all features aren't selected and;
if feature 1 is selected, disable feature 2 and 3
if feature 2 is selected, disable feature 3 and force install feature 1
if feature 3 is selected, force install feature 1 and 2
if feature 1, 2 or 3 is not selected, disable next button.
and if what I'm asking above is not possible, then is it possible to:
if feature 2 is selected, disable feature 1 and 3
if feature 3 is selected, disable feature 1 and 2
this question might have been asked and answered before, but after using the search bar, and googling it, I didn't find any topic similar to what I need, however it might because I use wrong search words.
thanks in advance
========edit=======
I found a workaround using checkboxes, this topic may be closed or deleted.
Re: Features and Quick Selection Tree
Hello Jacob,
