This happens because the Operating System
does not support CAB files larger than 2GB and thus, no single MSI larger that 2GB can be created.
For instance, a solution to this would be to have your resources next to your MSI (
"Builds" page -->
"MSI with resources next to it") or an EXE package.
By doing so, you can then choose to use
"One CAB archive per feature" option. The best way to do this would be to organize your installer into few big features (none of them exceeding the 2GB limit) and then use the above option.
Unfortunately, there is no other workaround for this issue since this is a limitation of Windows Installer.
