SteveTheBeez
Printable Manual
Hi
Is there a full printable manual i can download for advanced installer?
Cosmin
I'm afraid that we do not have a printable manual for Advanced Installer, but you can use our User-Guide:
http://www.advancedinstaller.com/user-g ... ction.html
Note that you can print our Help files by using the "Help -> Contents" menu. You simply right-click a tree (for example "Using Advanced Installer") and you select "Print".
If you encounter any problems or you have questions you can post them on the forum or you can contact us at support at advancedinstaller dot com.
Cosmin
Return to “Feature Requests”
