vanchen
Optional features in mixed package type
Hello!
I have got package type:"64bit" and build type:"single msi", optional features dialog show correct features (Tree of 2 features).
But then i used "mixed" package type and build type:"single exe", optional features do not show the tree (Only 1 first feature).
How can i made a tree of fetures in "mixed single exe" package type?
Thank you!
TestExe.aip
(12.29 KiB) Downloaded 234 times
vanchen
Re: Optional features in mixed package type
Found solution: Using Customise dlg instead of OptionalFeatures.
Thank you for your followup on this and for sharing your solution with us. I am sure this will be of help for further users facing a similar scenario.
