jsachs
File Associations
The pre-defined File Associations dialog box does not - as some other installers do - have buttons for Select All and Select None. Our application has different sets of users, some of whom ant to enable all the file associations and some don't want any. Checking or unchecking each association is an annoyance. Is this feature already supported in some form that I am unaware of by Advanced Installer? If so, please explain. If not, please consider this a feature request.
Re: File Associations
I have tested this scenario and indeed, you are right, the predefined dialog does not have buttons for selecting and unselecting all the file associations.
However, this can be achieved pretty easily:
Let's assume we have the following two extensions: exe and txt.
From this, two checkboxes are created in the "FileAssociationsDlg", having the following properties:
EXE_CHECKBOX
and
TXT_CHECKBOX
When selected, the above properties will have, by default, a value of "1". When unchecked, the value (of the properties) will be set to empty string.
So, here is you can achieve that:
- go to "Dialogs" page
- in the "FileAssoctiaonsDlg" dialog, add two push-buttons controls (one named "Select All" and the other one "Deselect All" - these changes can be done from the "Properties" pane of the control).
- now click on the "Select All" buton. Under "Published Events", please create an event as it follows:
Annotation 2019-09-25 100257.png (133.18 KiB) Viewed 21338 times
Now please repeat the above step for the second file association.
Now, please click on the "Deselect All" button and please repeat the above steps with the following modification:
- this time, the property will be set to the "{}" (without quotes) value, instead of "1".
This way, when these buttons are pressed, it should either select or deselect all file associations.
jsachs
Unfortunately, the method you are suggesting seems to require an Enterprise license which I do not wish to purchase. Am I missing something?
If not, let me request again that you add this as a selectable feature of the standard File Associations dialog as it should be useful to many users.
Indeed, you are right. The method I was suggesting requires the Dialog Editor feature which is available starting with the Enterprise suite or above.
I have added your request on our TODO list of improvements. Thank you for your suggestion.
I will update this thread when the improvement will be added to Advanced Installer.
jsachs
Thanks for your quick responses.
You are always welcome.
Kind regards,
This improvement has been added in version 21.5 of Advanced Installer.
