Hello Dan,
This can be achieved. However, this can be achieved only when the user presses the
"Next" button.
As you may know, every control from the dialogs has a property assigned to it that stores its value.
For instance, the edit box property will store whatever is typed inside it and the property of a checkbox will store (by default - this can be customized):
- "CheckBox" if the checkbox is checked
- "" (empty string) if the checkbox is not checked
In order to achieve what you want, we will need to set the properties of the edit box and the checkbox according to what the value of the radio button group (a radio button group is a control which contains 2 or more radio buttons) value is. By default, when you add a radio button group to one of your dialogs, it will look like this:
- RadioButtonGroup.png (157.2 KiB) Viewed 9188 times
By default, you can notice that the property is called:
RADIOBUTTONGROUP_1_PROP
Additionally, its default value is "
RadioButton_1", because the first radio button is selected. If the second radio button will be selected, its value will be changed to "
RadioButton_2".
Now that we have clarified that, in order to achieve what you want, you can proceed as it follows:
- go to "
Dialogs" page
- select the dialog that contains the radio button group, the checkbox and the edit box controls.
- click on the "
Next" button
- under "
Published Events", create as many events as you need, as it follows:
- EmptyEditbox.png (157.85 KiB) Viewed 9188 times
The condition can look like this:
RADIOBUTTONGROUP_1_PROP = "RadioButton_2"
if the second radio button is checked, then empty the property that stores the value of the edit box (makes the edit box empty)
In the exact same way (as described in the screenshot), you can uncheck the checkbox control.
Additionally, you can see all the properties of a control by clicking on it and then looking on the right pane, under "Properties" section. There, you can see the property assigned to a control , its default value, etc.
