zeeshanzaheer123
While Unstalling my setup I got the error
Hey. I have successfully installed the setup but when I got to uninstall the same setup it gives error attached to it please help
Re: While Unstalling my setup I got the error
Usually, that error message means that a custom action failed during the process (either install or uninstall).
Could you please give me some more details about what exactly you are trying to achieve through that .BAT file?
If possible, could you please forward me:
- a copy of your .AIP file
- a download link for the setup build with the above .AIP file
by e-mail at support at advancedinstaller dot com so I can further investigate this?
