IMayr
HTMLHost issue with AltGr
I would like to create an installer with an HTMLHost control. A website will be loaded in which a login should be done. The problem is that it is not possible to enter the '@' character in a text field. RegKey FEATURE_BROWSER_EMULATION has already been set to version Decimal 11000.
Thank you
Re: HTMLHost issue with AltGr
Hi and welcome to our forums.
I apologize for the late reply.
I'm not sure why you encounter this problem. Can you enter the '@' character in that field if you access the website from a browser? If so, can you send me a test project that reproduces the problem to support at advancedinstaller dot com, so I can investigate it?
