ClaesG
Create Report and Project Summery
discovered to my surprise that my favorite tool in the Advanced Installer has disappeared?
Where has the "Create Report" button gone?
Even then Project Summery button is missing....
It was in version -> 16.2 but not in 16.3 ..
Saw that there were bug fixes in the past.
Do you have any answer as to whether it has been removed or is a bug?
It was "the" best feature that saves me truckloads with hours regarding documenting my projects.
Best Regards
:ugeek:
ClaesG
Re: Create Report and Project Summery
Hello ClaesG,
The generate report can be found upon clicking on the "Project Summary" button:
ClaesG
Thanks, I found it.
Imo not the best place to put it though.
Have a nice day.
You are always welcome.
I am glad I could help.
Thank you for your feedback on this. We are working on improving our UI and we will take your feedback into consideration.
