nieksa
Issue with uninstalling Service when multiple versions are installed.
The current problem that I have with my AI project is quite annoying unfortunately.
I've made two versions of my service. 1.0.5 and 1.0.6 which can be installed side by side. They both have a different Product ID as is mandatory for an update. If I install 1.0.5 and uninstall it later on, it's removed accordingly. If I install both services, and try to uninstall version 1.0.6, the issues start to arise.
1. The program is still listed in Program List. When trying to uninstall it again it gives an error that the source files cannot be found.
2. When viewing the Task Manager, viewing the Services tab, I see that the service is still enabled. I'm able to stop it, but I'm not able to view the properties.
So I figured that it's an register problem. I've removed several keys and restarted my machine. Afterwards the issue was resolved.
I cannot expect my users to do the same, so they might run into some trouble. Because reinstalling version 1.0.6 is not possible. :(
Additional information:
AI 0.jpg (94.86 KiB) Viewed 4952 times
AI 1.jpg (37.55 KiB) Viewed 4952 times
Re: Issue with uninstalling Service when multiple versions are installed.
Unfortunately, I can not say for sure why that happens.
In order for me to further investigate this, could you please forward me the following:
From what I understand here:
you have created two versions of the prerequisites which are installed by different setups. Is this correct? If so:
- a copy of the .AIP file used to build the 1.0.5 version of your setup
- a copy of the .AIP file used to build the 1.0.6 version of your setup
- a download link for both your setups (1.0.5 and 1.0.6)
- a verbose log of the uninstallation process (when both versions are installed)
by e-mail at support at advancedinstaller dot com.
