dw833
New to AI - New project in VS doesn't contain a reference.
I'm new to Advanced Installer (AI) and having an issue I can't resolve. Using Visual Studio 2017 community edition.
I added an AI project to a solution and the references for the existing project was added to the AI project/References folders by default.
I didn't do anything to add the existing project to the references.
For a different solution, I added an AI project also. However, the existing project was not added to the AI Project/References folder.
I used the AI defaults when adding the AI project to both VS solutions. The two attachments show the difference.
So I'm not sure why there is a difference between how the AI project was added in the second solution.
Also, after the AI project is created how do I add a reference to a project in the same solution if they are not added when the AI project is created?
AI Second Solution with no references.PNG (4.18 KiB) Viewed 5636 times
AI First Solution with references.PNG (5.61 KiB) Viewed 5636 times
Re: New to AI - New project in VS doesn't contain a reference.
Thank you for trying out Advanced Installer.
Could you please make sure that you checked the "References" checkbox, when adding the Project Output to your Advanced Installer project?
If you did proceed like that, but this did not work, could you please create a sample solution for which this issue reproduces and send it over (together with all its dependencies) by e-mail at support at advancedinstaller dot com so I can further investigate this issue?
