Dava
Anticipate Registry Search over XML Search
Greetings,
I would like to execute an XML Search to store a value in a property. This search is for an upgrade, so I want to retreive values from XML files present on the machine, but I want to refer to them with the previous installation directory. In a registry value is stored the previous path, the thing I want is: resolved the path of APPDIR, setted by registry search, and then do xml search resolving APPDIR.
Thanks.
Dava
Re: Anticipate Registry Search over XML Search
Found by myself, just pu AI_Xmllocator before AppSearch in sequence table.
I'm glad you solved this. If you have other questions, just let us know.
