belsonmarble
Revoke registered trial
If a user installs an application where the serial was used via the installer, trial is initiated, trial begins, trial ends, user registers, license info is supplied, they're not registered.
1. So the user decides to copy the application folder to a new computer
2. They wish to transfer there license from an old computer to a new computer
Question: How can I set something up so if they register on the 2nd machine, that the 1st machine becomes unregistered, license gets revoked?
Re: Revoke registered trial
Unfortunately, I am afraid that we do not have predefined support for such a task. In order to achieve that, I think that you may have to achieve it in a custom way.
For more information about this topic, please have a look on our "Integrate licensing feature in VB projects".
Not sure if this will be of help, but the closest you can get with our predefined support would be to use a "user specific customized license" license format. For instance, you can use the "Computer specific" one, which means that the license will be valid only on the system from which it has been requested.
