wangruifeng
action text does not appear on The Enhanced User Interface
Hi
i have a problem that when i set "Enhanced user interface",the action text will not display on ProgressDlg.But when i set "Never Use Enhanced User Interface",the action text will display on ProgressDlg.Why is that?
Thanks in advance.
Re: action text does not appear on The Enhanced User Interface
I have tested this on our latest version of Advanced Installer (16.4.1) and everything was working as expected:
As it can be seen in the screenshot, I have tested this using a MessageBox custom action.
With that being said, could you please give me some more details about this issue? For instance, are you building your project using our latest version of Advanced Installer, or are you using an older version? Additionally, for which type of custom action the Action Text is not displayed? What theme are you using?
You previously mentioned that this works if Enhanced User Interface is not enable, so most probably this may not be the case, but I will mention it anyway: Please keep in mind that action text is displayed only for custom actions that are sequenced as deferred between the InstallInitialize (Preparing action group) and InstallFinalize actions (Finish Execution action group).
wangruifeng
First of all, i used the last version of Advanced Installer(16.4.1).
And my steps were:
1. I built a .Net Application
2. In order to have a long installion time , i added some files
3. I changed the "Use Enhanced User Interface" option to "Only on install".
4. I run it, it didn't display the standard action text(like "Copying new files", the default action).But when i changed the "Use Enhanced User Interface" option to "Nerver", it worked as expected
i didn't know why.Is it my mistake?Or is that what it is? I tried it in a new computer environment,too.
Thank you for your reply!
I have tested this once again and everything is working as expected. The only thing that I can think of right now that could make a difference is the used theme.
Are you using the "Classic" theme? If not, please let me know what is the theme that you are using so I can try and test this.
Additionally, if possible, could you please create a sample project (.AIP file) that replicates this behavior and forward it to me, either here or by e-mail, at support at advancedinstaller dot com? It does not have to contain any file (just the options), as I can use my own files in order to build and test it.
wangruifeng
See the attachments!
Thanks in advanced!
MyApp.aip
(23.14 KiB) Downloaded 436 times
Thank you for the provided project.
I have tested this and I can indeed confirm that you are right, for some reason the Action Text is not displayed when the Enhanced User Interface is used. However, I have noticed that this is particular to the "Chinese Simplified (PRC)" language option. For instance, if the main language is English, this no longer reproduces.
I have added this in our bug tracking system and hopefully this will be fixed in a future version of Advanced Installer.
I will update this thread as soon as the fix will be implemented.
Please let me know if you have any other questions and I will be glad to assist.
wangruifeng
No question!
Thank you very much for your patience!
You are always welcome!
My pleasure to help.
