Richard9
No detected files when importing a Visual Studio solution
I am attempting to follow the Importing Visual Studio Application tutorial https://www.advancedinstaller.com/user- ... -import-vs and, when I get to Detected Files, no files appear. If I check “Build selected configuration...” I get a window that begins to show a green progress bar, which quickly turns red and freezes. Screenshot attached
CAI VS import build error.png (2.9 KiB) Viewed 4420 times
I'm guessing the build has some kind of error, but this configuration builds and runs fine in Visual Studio. Is there any error log from the Visual Studio import wizard?
Re: No detected files when importing a Visual Studio solution
Hello Richard,
Well, this is indeed strange.
Unfortunately, I can not say for sure why this happens nor am I aware of any log files for the Visual Studio import wizzard.
In order for me to further investigate this, could you please forward me your Visual Studio solution (.sln file) and all its dependencies by e-mail at support at advancedinstaller dot com? If that is not possible, could you please create a sample solution file which replicates this issue and forward that instead?
Additionally, does this issue persists for all your Visual Studio solutions, or is it specific to one solution only?
