Dava
XML Search with add element
I want to store the attribute value of FweUrl in a property, how can I use XML-Search functionality to reach my objective?
Also, there are multiple add elements.
<Behaviours>
<add name="ViewFdsDocument" type="Eurosystem.SES.CoreEngine.DocumentActionBehaviours.ViewFdsDocumentActionBehaviour, Eurosystem.SES.CoreEngine.DocumentActionBehaviours" FweUrl="STONKS /^"/>
<add ........................ />
<add ........................./>
<add........................../>
</Behaviours>
Re: XML Search with add element
In order to achieve this, you can proceed as it follows:
- let's consider you have your XML file in the "C:\" directory
- please go to "Search" page and create a new XML search by pressing the "New XML Search" button from the ribbon
- here, you have to replicate the structure of your XML file. In the end, the search can look like this:
Dava
Forgot to mention there are multiple add elements
If there are multiple elements, then you can add them in Advanced Installer and configure the search accordingly. For instance, like this:
