jmcbee
Hitting "Install" Doesn't Do Anything
Hello, I apologize for how basic this question is. I have built my installer and when I run it I get to the view that asks me to check a box saying I agree to the licensing and then hit the "Install" button. When I hit the "Install" button nothing happens. I can't figure out what I am doing wrong. Any help would be much appreciated.
jmcbee
Re: Hitting "Install" Doesn't Do Anything
Below is a screenshot for context
Here is a screenshot for context
Install Not Working.png (185.55 KiB) Viewed 5722 times
This could happen if you manually edited our predefined control events on the related dialog. To double check on this you could create a new sample project and double check the built in control events configured on the related dialog (init events, published events and control conditions).
Otherwise, to further investigate on this please send us your .aip (setup project file) to support at advancedinstaller dot com so we can investigate its settings.
Update: this could also happen if you manually disabled the "Enhanced User Interface" feature. Please note that when using the Surface them the EUI feature must be enabled on all installation modes (install, maintenance, uninstall).
So, could you go to "Themes" page -> "Settings" tab and make sure the "Use Enhanced User Interface" option is set to "Always"?
jmcbee
Solved it, apparently I had to use a "Classic" theme for this to work.
Thank you for your follow up on this.
I am glad you got to a solution.
