In order to achieve that, you can make use of our
"Registry" page.
For instance, you can open the project, go to "Registry" page and create the registry keys required, together with the values. It can look something like this:
- run.png (164.16 KiB) Viewed 1897 times
One thing to keep in mind here is the fact that if your package is of 32-bit type and you install it on a 64-bit machine, it will be redirected in the WOW6432Node, like this:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Run
instead of
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
