phillip.byram
Url shortcut files being marked as ini files in project report
I added a url shortcut to the desktop using the following menu:
Annotation 2019-11-11 163324.png (13.16 KiB) Viewed 1952 times
Strangely, both the generated project report and the project summary list that these .url files are ini files:
Annotation 2019-11-11 163203.png (22.44 KiB) Viewed 1952 times
Shouldn't they be listed in the shortcuts area?
Is this a bug or is there some other explanation to the mislabeling of these url files?
I am on AdvancedInstaller 16.3
Thanks!
-Phillip
Re: Url shortcut files being marked as ini files in project report
Hello Phillip,
An URL shortcut is not a "real" shortcut, but an INI file.
Since we support working with INI files, we decided to place that under the "INI Files" section in the "Project Summary" tab, since that's what it actually is.
