blackpanda
Custom Action Message Box was showed behind the the form
My custom action message box was showing behind the form and user has to click on the icon on the taskbar or move the form to see the message. Could you please tell me how can I bring it on top?
Thank you
Re: Custom Action Message Box was showed behind the the form
Unfortunately, I can not say why this issue occurs.
Do you use our predefined "MessageBox" custom action or are you trying to spawn the messagebox from within a script (e.g. PowerShell, VBS, etc.)?
In order for me to have a better view about this, could you please forward me a copy of your .AIP file by e-mail at support at advancedinstaller dot com? You can strip it down from its files (i.e. delete them) and just send it like that so I can build and test it on our end.
Hello Hieu,
First of all, thank you for the provided files. I was able to build the project and successfully replicate the behavior.
Unfortunately, I can not say for sure why this happens. It seems that somehow the message box does not obtain the handle from the parent window, resulting in it being displayed in the background.
I have forwarded this to the development team and we will further investigate to try and find the root cause of this.
In the meantime, you can use another custom action to spawn the message box. For instance, I have tested this with an inline VBScript and everything worked as expected - the messagebox is spawned in the foreground. Please follow these steps in order to achieve it:
- go to "Custom Actions" page and add an "Execute inline script code" custom action without sequence
- the custom action content could look like this:
MsgBox (Session.Property(REBOOT_MESSAGE))
- go to "Dialogs" page and remove the default messagebox custom action. Instead, please add another event on the "Next" button which will execute the inline VBScript.
Also, when we will have a resolution on this, I will update this thread.
Hello Hieu,
This has been fixed in Advanced Installer 16.7, released on January 15th, 2020.
