scambias
Using DetectService multiple services
Hi all,
I have to build a setup that has two services as features: I need to detect if they're installed so I was thinking to use the DetectService custom action twice (I can rename them). The thing is that the property they generate has the same name (AI_SERVICE_STATE): how can I distinguish whether one or the other service has been detected?
Am I wrong on something?
Thank you very much.
Re: Using DetectService multiple services
Indeed, you are right. If you will use two custom actions, the value of the property that stores the results will be overwritten.
A workaround for this would be to have a "Set Property" custom action after each of your "DetectService" custom actions. Basically you will set two different properties (one for each of your servives) to the value of the AI_SERVICE_STATE property. For instance:
DetectService
Set property to the value of AI_SERVICE_STATE
DetectService
Set another property to the value of AI_SERVICE_STATE
After doing so, you can use the two new properties to fulfill your needs.
scambias
Thank you very much for your quick reply!
You are always welcome!
Glad I could help.
