scambias
Assign nt rights to user: where to place the custom action?
Hi all,
I have the issue to assign a bunch of NT rights to a user that has just been created.
I know I can write a custom action script using the command ntrights.exe, but I need to know when the user is created in the flow of the setup execution.
Can anybody please help me?
Re: Assign nt rights to user: where to place the custom action?
If a new account is added in the "Users and Groups" page, an action that "installs" the account will be added between the "AllocateRegistrySpace" and "ProcessComponents" standard actions, during the "Preparing" action group in the "Install Execution Stage". Therefore, you should add your custom action after the "ProcessComponents" standard action.
In order to display the "ProcessComponents" standard action in the "Custom Actions" page, please right click on "Preparing" action group --> "Show Standard Action" --> "Preparing" --> click on the "ProcessComponents" action
scambias
Thank you very much!
Kind regards,
Silvio
You are always welcome, SIlvio.
Glad to help.
scambias
One more question: I need the files being deployed since the command I use to assign nt rights is actually among the installed ones.
When the actual deploy of the files under APPDIR folder takes place?
I tried to place this script run just before the InstallServices (please see the attached picture) but with a message box placed there I could break the execution to see whether the grant-rights application path was existing and it was not (in fact it reacts with a path not found error and the setup terminates).
More in general, is there a place where I can read about those events of the sequences of the installation? I have seen from those right click menu you showed me they are quite a lot!
The files are copied on the target machine during the "Add Resources" action group, on the deferred stage.
Most probably, this happens due to the fact that your custom action is scheduled to run during the "Immediate" stage, whereas the files are copied during the deferred stage. Could you please go to "Custom Actions" page --> select your custom action --> under "Execution Time" please select the "When the system is being modified (deferred)" radio button? This way, the custom action should be executed after the files are copied on the machine, therefore everything should work as expected.
scambias
Thank you!
At this time, properties are still available (and valued as expected)?
Because just after modifying the time when to execute the script, it seems I can't get APPDIR or other property value.
Thanks again,
Silvio
scambias
I guess I missed this info on the help. Sorry ;)
I've read this:
https://www.advancedinstaller.com/user- ... ction.html
Sorry to ask something was already written in the doc!
Kind regards,
Silvio
You are always welcome, Silvio.
