Hello Silvio,
I have tested this scenario and everything worked as expected for me.
Few things I could notice in your screenshot:
1. you set the
AI_USER_IGNORE_FULLNAME property to
1. I don't think it's necessary to set this property, as you can enable the
"Check only user names and ignore profile names" option from the
"CheckIfUserExists" custom action:
- CheckOnlyUsername.png (123.87 KiB) Viewed 2622 times
2. you set the
AI_USER_IS_GROUP to
0. The
"Search in users" / "Search in groups" option from the
"CheckIfUserExists" custom action is equivalent to setting AI_USER_IS_GROUP property to 1 for checking user groups instead of accounts.
- SearchInUsers.png (122.91 KiB) Viewed 2622 times
3. you set the
AI_USER_CHECK_PASSWORD to
1. This is equivalent to checking the
"Check user account's password" option from the
"CheckIfUserExists" custom action. Even if this is done, I couldn't see in the screenshot the place where you set the password for your account. Please keep in mind that this also has to be specified before checking the validity of the account. The property which has to be set in this case is:
So basically, I think that you could remove the above
"Set property" custom actions and do the changes directly in the
"CheckIfUserExists" custom action. In addition to that, if you will check for the user password, please do not forget to also set it.
Here is a screenshot which highlights how I've tested this:
- MyTest.png (238.16 KiB) Viewed 2622 times
