jbord
Memory consumption: Service vs Executable application types
We've been using Advanced Installer create an executable for a Java application on Windows. We noticed that when we run it as an executable (Application Type=executable), it has a lower memory footprint than when we run it as a Windows service (Application Type=service). Another difference is that when we run it as a service, we run it under System, but when we run it as an executable, it is run under an administrator account.
Do you have any idea why this might be the case? The difference in footprint is quite significant (100s of MBs).
Thanks!
Jonathan
Re: Memory consumption: Service vs Executable application types
Hello Jonathan and welcome to Advanced Installer forums,
Unfortunately, I am not quite sure I understand your scenario here.
By this, do you mean that your java application is consuming more memory when its type is of "Graphical User Interface"
as opposed to when its type is of "Win32 Service"?
If this is the case, I'm afraid that I'm not aware why this happens. I have run a small test using this scenario as a starting point and I could notice (using task manager) that the memory consumption is the same. I have also discussed with the developer and he mentioned that he is not aware either of any case in which the memory consumption is increased when the application type is changed from GUI to Win32 Service.
This leads me to think that this might be related to the application itself.
Please let me know if that is not the case and I will try to further investigate this.
In what regards this, indeed, you are right. The SYSTEM account is used by the operating system and by services that run under Windows. There are many services and processes in the Windows operating system that need the capability to sign in internally, such as during a Windows installation. The SYSTEM account was designed for that purpose, and Windows manages the SYSTEM account’s user rights. It is an internal account that does not show up in User Manager, and it cannot be added to any groups.
