Yes, this is achievable.
Before we start, a little explanation. Almost every UI control has a property assigned to it. In the case of a checkbox control, the property is used to store its state, as it follows:
- the property has (by default, can be changed) the
"CheckBox" value if the checkbox is checked.
- the property has the "" (empty string) value if the checkbox is unchecked.
More information in the below screenshot:
- checkbox.png (110.26 KiB) Viewed 3398 times
Basically, in order to check a checkbox, we can set its property to the
"CheckBox" value. To do so, you can go to "Dialogs" page --> your dialog --> select the checkbox on which the selection of the second checkbox depends (in our case, its checkbox_A, because we want to enable checkbox_B only if checkbox_A is checked) and, under
"Published Events" add an event as it follows:
Event: Set installer property value
Property: CHECKBOX_2_PROP
Argument: CheckBox
Condition: CHECKBOX_1_PROP = "CheckBox"
The above event translates to: set the CHECKBOX_2_PROP (which is the property assigned to our checkbox_B) to "CheckBox" (check it) if CHECKBOX_1_PROP (the property assigned to checbox_A) is equal to "CheckBox" (it is checked).
