Kiriko
No volume space for installpackage
Hi guys,
I can't see the [PrimaryVolumeSpaceRequired] in my installer.
i use the checklist and blacksurface.
what should i do?I want to use [PrimaryVolumeSpaceRequired].
Re: No volume space for installpackage
When the Enhanced User Interface is used, you no longer need to set the AiEarlyValidate property.
However, you still need to set the PRIMARYFOLDER property to "APPDIR" (without quotes). To do so, you need to create a new "SetProperty" custom action. I'm not sure if you've set this property as it does not appear in your screenshots.
Please have a look on the following project which I've created for your reference:
DiskSpaceValidate.aip
(37.03 KiB) Downloaded 217 times
