NovAtel
Environment Variable Max Length
I'm creating a user Environment Variable via System Changes > Environment. This environment variable is the path to a UWP app.
I want to be able to add multiple paths for each new version I have. If I use the prepend the option to add the new path to the environment variable during each installation so that it looks something like this...
MY_ENV_VAR =
C:\Program Files\WindowsApps\<Name>_19.11.0.0_x86__<PublisherId>;
C:\Program Files\WindowsApps\<Name>_19.10.0.0_x86__<PublisherId>;
C:\Program Files\WindowsApps\<Name>_19.09.0.0_x86__<PublisherId>;
C:\Program Files\WindowsApps\<Name>_19.08.0.0_x86__<PublisherId>;
etc.
I'm wondering what happens when the variable eventually reaches the max length. Will it fail installation? Will it push out the oldest path? Other?
Re: Environment Variable Max Length
At install time, we only populate the Environment table, the rest being done by the predefined support offered by Windows Installer (e.g. the predefined WriteEnvironmentStrings custom action that creates the environment variable).
From my tests so far, when the prepend option is used and when the maximum length is reached, the last n characters are removed from the queue, where n is the number of characters you have prepended to the already existing environment variable. For instance, if 6 is the maximum number and we have the following environment variable:
envVar = aaaaaa;
and then we try to prepend "bbb", the environment variable will become:
envVar = bbb;aaa;
