sonda
Path variables not applied to theme images
I have used path variables in my project, but when i save project images for the theme are saved with relative path all other variables are replaced with path variables and now when i do automatic build images are missing.
Question is how can set path for the theme images to be configured try path variables, or how can i configure them?
Re: Path variables not applied to theme images
In order to achieve this, you can use the "Convert Paths" wizard from the toolbar and make sure that the "Resource Files" category is selected for conversion.
