Hello Fred and welcome to Advanced Installer forums,
First of all, I am glad you gave Advanced Installer a try.
Yes, it is possible to achieve what you want. All you have to do is to add the spreadsheet file in the
"Desktop" folder from the
"Files and Folders" page.
- Desktop.png (141.64 KiB) Viewed 1926 times
In order to add a file there, you can go to
"Files and Folders" page --> click on the
"Desktop" folder and then, on the right side, right click and select
"Add Files":
- AddFiles.png (173.64 KiB) Viewed 1926 times
This way, the file will be copied on the Desktop during the installation.
One thing to be kept in mind here is the fact that, as you may know, there are at least two Desktops folders on pretty much all machines, and those are:
- the public desktop which is available to all users
- the user's desktop which is available to only the logged on user
Therefore, the Desktop folder from your Advanced Installer project can also be resolved to two values (those specified above). This is decided through the installation type.
You can see the installation type by going to
"Install Parameters" page -->
"Installation Options" section -->
"Installation Type".
By default, the installation type is set to
"Per-machine only (fails if user is not administrator". As its name suggests, this is an installation performed per-machine, therefore the Desktop folder (from your project) will be resolved to the Public Desktop (which means the spreadsheet will be available to all users).
More information about the installation type can be found in our
"Install Parameters Page" article.
