Ja7adR
how to copy file and folder from temp to application directory by select Radio button
hi
i want set radio button action for copy file and folder from temp folder to application folder with replace file and folders.
how to do it?
i try this but i don't understand: viewtopic.php?t=34691
Re: how to copy file and folder from temp to application directory by select Radio button
In order to achieve that, you can proceed as it follows:
Let's suppose that you have a file called asd.txt added as a temporary file:
In order to copy/move it from that folder to your "Application Folder", please go to "Files and Folders" page --> select "Application Folder" --> right click on the white area --> "New File Operation" --> "File Copy/Move". Your file operation should be configured as it follows:
where:
"Source File --> Name" field is the name of the file to be copied/moved and the "Source File --> Folder" is the folder where the file resides. As you can see in the screenshot above, the folder is set to "TempFolder" because that is the folder where our files is.
"Destination File --> Name" field is the new name of the file to be copied/moved and the "Destination File --> Folder" field is the folder where the file should be copied.
In addition to that, you have the condition field where you can condition the file operation based on your radio button.
In what regards the radio button selection, I suppose that you have in one of your dialogs a "Radio Button Group" control, which contains at least 2 radio button controls, as it follows:
As highlighted in the screenshot, this control has a property assigned to it. In our case, the property is called:
RADIOBUTTONGROUP_1_PROP
Inside of the Radio Button Group control, there are two radio buttons, which have two values:
The values, by default, are:
RadioButton_1
and
RadioButton_2
Based on this, you can use the value of the RADIOBUTTONGROUP_1_PROP to condition the file operation. For instance, if you want to copy the file only if the first radio button is selected, the condition field could look like this:
