abdulrehman_binaltaf
BCDEDIT windows 10 upgrade
common issue in windows7 32bit upgrade is NX feature need to enable.
how we automate the below mentiod commad.
bcdedit.exe /set {current} nx AlwaysOn
Re: BCDEDIT windows 10 upgrade
This might be achieved using our predefined "Launch File" custom action. For instance, you can launch cmd.exe and then execute your command.
The custom action can look as it follows:
Basically here, we will launch the cmd.exe with the /c parameter which tells the main window to execute the command and the exit. What comes after "/c" in quotes should be your command, e.g.:
Unfortunately, I am not familiar with the "bcdedit.exe" tool, therefore I can not say for sure if this will work. I suggest you test this on a Virtual Machine.
