MLiss@Cetrus.com
Install and start multiple services - which gets started first?
I would like to know what which service will start first, given this configuration (or any configuration for that matter)
NOTE: Both services "Control Operations" are the same : "Start" on install
Re: Install and start multiple services - which gets started first?
Hello MIke,
The services should be started in the order specified. For instance, in your case, the order should be as it follows:
ManagerCommandService43 --> ManagerService43
