tekomino
How to include Serial dialog per build
I am evaluating product and so far I've been able to do almost everything I need. There is one thing though that I am struggling with.
I have the installer with 4 builds. For 2 of these builds I want to ask for serial number but not for other 2. I would prefer not to include serial dialog with accompanied DLL at all into the builds that do not ask for serial.
Any suggestions on how I can do this with Enterprise version? Are there command line options that would allow turning off the serial number feature?
Any help is much appreciated.
Cosmin
I'm afraid that this feature is not supported directly, however, you can do this by using conditions for custom control events.
For example:
- you have two builds: Build1 and Build2
- in the "Dialogs" page you go to the "WelcomeDlg" dialog and select the "Published Events" tab for the "Next" button
- you set these control events:
NewDialog       FolderDlg              AI_INSTALL AND AI_BUILD_NAME<>"Build1"
NewDialog       UserRegistrationDlg    AI_INSTALL AND AI_BUILD_NAME="Build1"
- this will show the "UserRegistrationDlg" dialog only for the Build1 build
- for the "Back" button on the "FolderDlg" dialog you set these control events:
NewDialog       WelcomeDlg             AI_INSTALL AND AI_BUILD_NAME<>"Build1"
- now you need to make sure that the custom action associated with the serial validation feature is executed only for Build1; for this you open the AIP with a text editor and you find this line:
<COMPONENT cid="caphyon.advinst.msicomp.MsiInstExSeqComponent">
- under it you modify the ROW Action="AI_VALID_SERIAL" to look like this:
<ROW Action="AI_VALID_SERIAL" Condition="(NOT Installed) AND (UILevel <> 5) AND (ProductID) AND (AI_BUILD_NAME="Build1")" Sequence="725"/>
- basically you add the (AI_BUILD_NAME="Build1") condition to the serial validation custom action in order to execute it only for Build1
If you need a sample project then please contact me at support at advancedinstaller dot com.
Cosmin
tekomino
Thank you so much this is very helpful.
