burnersk
How do I get the Advanced Installer version to be written into summary information?
With an MSI build, under "Database Encoding", you have "Customize Summary Information" with the field "Creating Application".
In this "Creating Application" meta field, Advanced Installer stores "Advanced Installer build".
I want to change this to "Advanced Installer $AdvancedInstallerVersion", so I always can see which version of Advanced Installer I have used to produced the individual setup file.
There are some useful but undocumented properties available, such as [|AI_CURRENT_YEAR], which I use for Copyright notices. I bet there is also something like the Advanced Installer version (similar to ProductVersion).
Is such property available, and what name does it have?
Re: How do I get the Advanced Installer version to be written into summary information?
Under "Creating Application" field, you could use the "Use default value (generated at build)".
I have tested this now and I could notice that the following information is logged:
