burnersk
How to temporary disable/enable Digital Signature via command line
I have two scenarios:
  • release builds, which I sign with Advanced Installer, and
  • (automated) development builds, which are not signed at all.
I want to have a single Advanced Installer configuration file, but still want to choose whether I want to sign or not.
Is there a way to temporary disable/enable the Digital Signature functionality via the command line (automated build process)?
Re: How to temporary disable/enable Digital Signature via command line
In order to achieve this, you can use the ResetSig and SetSig command line parameters:
ResetSig --> Resets the digital signature. The effect of this command is equivalent to unticking the option “Enable signing” in the Digital Signature page.
SetSig --> Opposite for command ResetSig. The effect of this command is equivalent to ticking the option “Enable signing” in the Digital Signature page.
For more information about this, please have a look on the following article:
Executing a files of commands
burnersk
Thank you Catalin, this was a clear case of myself of not reading carefully.
But in my defense, section 6 points out "Parameters" with three (bold) bullet points. It gives the feeling of that is all; so I have skiped this section and went to the next one.
A (low prio) suggestion: Please rearrange the parameter section, so it is clear what "all the parameters" are ;)
You are always welcome!
I am glad that helped.
I have forwarded your feedback to our Technical Writing team and the article will be updated in the future.
Thank you for your suggestion.
