AlexanderAnishchik
Search Registry issue
I'm trying to save MariaDB (MySQL) data folder path to installation property. To achive this goal I use Search feature with Registry Location Property. But result of search is empty somehow (please see attachment). If I set "Search the 64-bit portion of the registry" checkbox it returns path with "Program Files x86" part but actually path is "Program Files". What should I change?
AlexanderAnishchik
Re: Search Registry issue
So the problem is when checkbox enabled it returns worng path from variable
Hello Alexander,
The fact that it returns nothing when you don't check the "x64" checkbox is due to registry redirection (the WOW6432NODE registry key).
The Wow6432Node registry entry indicates that you're running a 64-bit version of Windows. The OS uses this key to present a separate view of HKEY_LOCAL_MACHINE\SOFTWARE for 32-bit applications that run on a 64-bit version of Windows.
However, the fact that the returned value is not the exact one as in your registry is really strange.
Could you please let me know how have you tested this? Have you used the "Test Search" button from the toolbar? If so, could you please test it like this and let me know the results:
- go to "Custom Actions" page
- add a "MessageBox" custom action
- schedule it after the "Searches Action" group in the "Wizard Dialogs Stage"
- the custom action content should be set to:
[MARIADB_DIR]
- rebuild & run the setup
A message box containing your path should be spawned upon installation. Could you please let me know if the result is the same as before?
AlexanderAnishchik
When I use "Test Search" it returns wrong value but if use it on UI (when installation process started) it returns correct one.
Well, the "Test Search" functionality is not always the most accurate.
However, I am glad everything is working as expected when you actually run the setup.
AlexanderAnishchik
Ok, thank you
You are always welcome!
