AlexanderAnishchik
Access AI_ProgramFiles
Can I access AI_ProgramFiles value inside of Powershell Inline Script that run before installation of prerequisites? I want to rename old MariaDB folder before of installation MariaDB as prereprerequisite. But the value of property AI_ProgramFiles and custom search is empty.
Here is my script:
# Block for declaring the script parameters.
Param()
$mariaDBInstalled = AI_GetMsiProperty MARIADB_DIR
Write-Output $mariaDBInstalled
$programFiles = AI_GetMsiProperty AI_ProgramFiles
$path= $programFiles +"MariaDB " + (AI_GetMsiProperty MARIADBVERSION)
Write-Output $path
$newname="Old MariaDB " + (AI_GetMsiProperty MARIADBVERSION) + "Backup"
# Your code goes here.
if((Test-Path2 $path) -AND ($mariaDBInstalled -EQ "NULL")){
Write-Output "IF SUCCESS"
		Rename-Item -Path $path -NewName newname
How can I achive that?
Re: Access AI_ProgramFiles
Hello Alexander,
Could you please try to retrieve the "ProgramFilesFolder" property instead? The AI_ProgramFiles is a custom made property and I am not quite sure if you can retrieve its value.
With that being said, your script could look like this:
$programFiles = AI_GetMsiProperty ProgramFilesFolder
AlexanderAnishchik
It works but returns C:\Program Files (x86) while my application mixed 64/32. It seems like we can't fetch value of Custom Search in Pre-Install section. Is it true?
Hello Alexander,
The ProgramFIlesFolder property resolves based on Operating System bitness. It resolves to:
C:\Program Files
C:\Program Files (x86) -- on a 64-bit machine
If you want to set it to "C:\Program Files (x86)" on x86 machine and to "C:\Program Files", you can condition it in your script, as it follows:
$versionNT64 = AI_GetMsiProperty VersionNT64
if($versionNT64 -eq ""){
$progFiles = AI_GetMsiProperty ProgramFilesFolder
else{
$progFiles = AI_GetMsiProperty ProgramFiles64Folder
VersionNT64 is a property which is set only on 64-bit machines, therefore we can use it to condition setting the value of the $progFiles variable.
AlexanderAnishchik
Thanks it will help. Is it possible to use custom variables such a result of the search in Pre-Install sections? I can't access this value before prerequisites but it accessible when main installation is started.
Hello Alexander,
Yes, that should be possible.
The easiest way in which you can check this is by using a MessageBox custom action which will print the result of your search.
Please follow these steps:
- in "Custom Actions" page, please add a "MessageBox" custom action without sequence (press the "Add custom action without sequence" button which is placed to the right side of the custom action's name)
- in the "Message" field of your custom action, insert the name of your property enclosed in square brackets (e.g. [RESULT_PROPERTY])
- now please go to "Dialogs" page and under "Pre-install UI", please select "WelcomePrereqDlg" dialog. After doing so, select the "Next" button and, under "Published Events" tab, click the "New..." button and add an event as it follows:
Event: Execute Custom Action
Argument: MessageBox
Condition: leave unchanged
- build and run your setup. The messagebox should print the value of the property that stores the result of your search.
