rahmadi89
Make a single line value with type REG_MULTI_SZ
Hello
how I can to build a single line REG_MULTI_SZ value in registry and replace the data ?
for example Something like this:
Key: HKEY_CURRENT_USER\testkey
Value Name: testvalue
ValueType: REG_MULTI_SZ
ValueData: text
when I add this value in REGISTRY section at AI16.5, because the value is single line, AI will automatically set this value type to "REG_SZ"
with some searching in your forums I found that maybe using "[~]" solve my problem but no. When I add "[~]" at the end of data, the Prepend or Append option will selected depending on location of entering "[~]". But I want the data be Replaced not prepend or append.
Re: Make a single line value with type REG_MULTI_SZ
Unfortunately, this is a Windows Installer limitation.
If a [~] follows the end of the string list (as you did), the strings are to be prepended to any existing registry value strings. If a prepending string already occurs in the registry value, the original occurrence of the string is removed.
For more information about this, please have a look over the "Registry Table" Microsoft article.
After some further testing, I think I may have found a workaround for this. In the "Data" field, please insert your value as it follows:
testValue[~]
after the [~] character, simply insert a space character (if you try to copy the above expression you can notice the extra space).
This way, the registry type will be set to "REG_MULTI_SZ" and the "Replace existing value" option will be chose.
