Hi Thanks for reply and if if you see in the .aip file i set one property (SERVICE_EXISTS_PROP ) on beginning andn initialise to 0,
- err1_.png (4.97 KiB) Viewed 6252 times
after that i add custom powershell script that is runned before gui and that script should set property to (SERVICE_EXISTS_PROP =1)
- err-2a.png (38.03 KiB) Viewed 6252 times
and at last there is launch condition that check if the property is set to 1 (this should be 1 because custom script should set it, and should be executed before launch check script) and should not be triggered, but if you try to run aip will see that launch condition is triggered and installation not continue and thats the problem, like custom script is not executed and property is not set to 1
- err2.png (15.68 KiB) Viewed 6252 times
