thomaslevesque
Cleanup not removing additional files
My app writes some data (database, user settings, etc) in subfolders of the Application Data folder. During uninstall, I'd like to remove those files (after asking the user). I set it up like this, using the "Uninstall Cleanup" wizard:
However, when I uninstall the app, the data and logs folders, and their contents, are not removed.
What am I missing?
Re: Cleanup not removing additional files
I have tested this just now and everything worked as expected for me.
First of all, as you can see, the folder removal happens only if a component is uninstalled. Given this scenario, could you please create (if not already created) a verbose log of the installation process and forward it to me for further investigations (also, I will need the name of the component, if possible)?
This might happen if the component you have selected is not marked for uninstallation.
thomaslevesque
Thanks for your reply. Actually, looking at the logs made me realize my mistake. I thought "Application Data" in the Files and Folders view referred to the application-specific folder in AppData/Roaming, but it's actually the AppData/Roaming folder itself.
So I assume I need to do something like this instead:
However, it looks like the placeholders are not replaced, it uses the values "[Manufacturer]" and "[ProductName]" literally... How can I solve this?
thomaslevesque
Ah, never mind, I got it working.
I had to use "[|Manufacturer]" and "[|ProductName]" as the placeholders.
BTW, why do I sometimes need to use "[|name]" and sometimes just "[name]"? What's the rule to know which to use?
Indeed, you are right, the "Application Data" folder basically represents the %appdata% folder, which is, as you have mentioned, the "AppData\Roaming" folder.
For more information about this, please have a look over our "Paths to the folders in the Files and Folders page" article which I think you may find useful.
In what regards this, as you have mentioned, the properties should be written as this:
[|PROPERTY]
A Windows Installer property can be used in two types of fields:
- Formatted type fields
- Pseudo-Formatted type fields
Basically, the main difference between them is the following:
- properties inserted in formatted type fields are resolved at runtime
- properties inserted in pseudo-formatted type fields are resolved at build time
thomaslevesque
Ah, I see, thanks for the clarification!
You are always welcome!
I am glad I could help.
