mccorkled
Edit XML File
Is there a way that I can have AI open and XML, add lines of text in alphabetical order, save, and close? I would also need it to remove those lines upon uninstall. This is a very important.
Thank you :)
Re: Edit XML File
Is the XML file in subject part of your installer (added in "Files and Folders" page), or is it supposed to already exist on the client machine?
mccorkled
Re: Edit XML File
It is part of the initial installer. I have a main base package, and add-on packages. I need to edit the XML from the initial package (after it is installed on the machine) to include lines that will allow the add-on packages to be visible once they are installed. I hope this makes sense.
Re: Edit XML File
Let's consider we have the following .XML file:
<?xml version="1.0"?>
-<note>
<to>Tove</to>
<from>Jani</from>
<heading>Reminder</heading>
<body>Don't forget me this weekend!</body>
</note>
When adding the above (or any) .XML file in Advanced Installer, you are being asked if you want to add the file in Windows Installer format.
If you add the .XML file in Windows Installer format and then double click on it, you will be able to edit it.
mccorkled
Re: Edit XML File
Thank you, I will give this a try.
Re: Edit XML File
You are always welcome!
mccorkled
Re: Edit XML File
I believe that did the trick!
Thank you again for your help. By chance, are you one of the people that work on Newspaper X? I have seen several very familiar names here.
Re: Edit XML File
I am glad that helped.
No, I am not working on Newspaper X. Most probably, just a name coincidence.
