mccorkled
Features with Radio Buttons
Hello again Catalin,
I have really appreciated your help over the last few day. I have ran into one more thing that I do not understand fully after reading the guides...
I am trying to install features using radio buttons. I have two files with the EXACT same file name, but only one needs to be installed by the user depending on which one they want to use. Where can I store these files temporarily before the user picks one to install? They cannot go in the same directory because of them having the same file name, but I also do not want both sitting on the machine after install.
Re: Features with Radio Buttons
I am really glad I could help!
Most of what you want to achieve is possible with our predefined support. Please allow me to explain how this can be achieved:
Let's start with the beginning. In the "Files and Folders" page, please create two folders under the "Temporary" folder.
Now please click on the first folder --> "Add Temporary Files" button from the ribbon. Now please add the first version of your file.
Now please click on the second folder --> "Add Temporary Files" button from the ribbon. Now please add the second version of your file.
Now that the files are added, if you double click on the file, you will notice that it has a property assigned to it. This property stores its path (we will need this a bit later).
You have mentioned that you want the files to be installed based on a RadioButton control. With that being said, we need to add a "Radio Button Group" control to one of our dialogs. To do so, please:
- go to "Dialogs" page, select one of your dialogs (e.g. "WelcomeDlg")
- in the ribbon, please click on the "Controls Toolbox" button
- from the list, select the "Radio Button Group" control and add it to your dialog.
- now, if we click on the control, we will see that it has a property assigned to it as well. This property stores the state of the control (e.g. which radio button was selected)
If you click on each radio button, you can see the values that the "RADIOBUTTONGROUP_1_PROP" property can take:
RadioButton_1
respectively
RadioButotn_2
Now, normally, we should achieve what we want through a "File Copy/Move" operation. However, this is not possible, because the destination file name can't be the same for two operations.
In the above screenshot you can see how a "File Copy/Move" operation looks like. As you can see, it has, as parameters, a source file and a destination file. The destination file name is actually the name of the copied file.
As you can imagine, in our scenario, we would need two such operations. The thing here is that, unfortunately, the destination name can be the same for two operations.
With that being said, we can not use our predefined support for this task. However, this is possible through a custom approach (a custom action) - e.g. a script.
For this, we can use a script (e.g. PowerShell, VBScript) that will copy our file from the temporary location to our application directory (APPDIR) based on the radio button selection. Here is how the script could look like:
# Block for declaring the script parameters.
Param($appDir, $sampleOne, $sampleTwo, $radioButton)
# Your code goes here.
# based on the radio button selection, we copy our files from the temporary location to APPDIR
if ($radioButton -eq "RadioButton_1"){
Copy-Item -Path $sampleOne -Destination $appDir
elseif ($radioButton -eq "RadioButton_2"){
Copy-Item -Path $sampleTwo -Destination $appDir
To implement this in Advanced Installer, please go to "Custom Actions" page. Here, please add a "PowerShell inline script" custom action, with sequence.
In the end, the script should look like this:
Some information about the "Copy-Item" PowerShell cmdlet can be found here:
https://docs.microsoft.com/en-us/powers ... wershell-7
This way, based on the Radio Button selection, one of your files will be installed.
Also, temporary files are deleted at the end of the installation ---> none of the files will be found on the target machine (in the temporary location) after the installation - only the copy filed will be found.
mccorkled
Thank you for that very detailed explanation. I believe I understand this well now. If the file needed placed into a sub folder would it be something like..
[APPDATA\Folder2\Folder3]
You are always welcome.
I am not quite sure I understand your question here. Could you please give me some more details?
mccorkled
Catalin wrote: ↑Fri Feb 14, 2020 10:27 am I am not quite sure I understand your question here. Could you please give me some more details?
The PowerShell script is placing the file chosen into the root [APPDATA] folder. I need it to go into a sub folder within [APPDATA] Is the below the correct way?
Also, when I run my installer it fails with the error...
Dumping PowerShell invoke log ...
--> Found PowerShell path: C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powershell.exe
--> PowerShell Script Execution Result Code: 574
dows 10\AppData\Local\Temp\pss7080.ps1 : Caught Exception: Missing
an argument for parameter 'radioButton'. Specify a parameter of type
'System.Object' and try again.
    + CategoryInfo          : NotSpecified: (:) , WriteErrorExcep
   tion
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorExceptio
   n,pss7080.ps1
I've tried several methods and am a bit stumped.
In order for me to further investigate this, please forward me a copy of your .AIP file, either here or by e-mail at support at advancedinstaller dot com.
mccorkled
Ok, I sent it over. Thank you.
Thank you for the provided .AIP file.
After further investigating it, I have noticed that your radio button group has the following property:
RADIO
not
(you probably have renamed it)
With that being said, could you please change it in your PowerShell script?
mccorkled
Thank you! I am not sure how I missed that. I'm glad to know my modified script works. :)
You are always welcome!
I am glad everything is working as expected now.
Hello guys,
This is a followup post in case more users are facing the same scenario, as we managed to find a much easier and elegant solution.
Basically, if you have two files with the exact same name and want to install only one based on a condition, you can proceed as it follows:
- in "Files and Folders" page, create two distinct folders under "Application Folder"
- in each folder, add your file
- right click on the first folder --> "Properties" --> select "Install folder content into the parent folder" option
- repeat the steps for the second folder as well
- now select your file and right click on it --> "Go to component". Here, you can condition the installation of the component
- repeat the above step for the second file as well
