underground_miner
Unexpected Exception when opening project
I am running v12.8 build 69285. I recently switched to Windows 10 from windows 7. When I try to open my installer project I get an unexpected exception error. I have attached a screen capture.
I have tried downloading and installing the latest version, 16.7 and it gives the same error. How do I get past this?
I have tried inspecting the aip file using a text editor but I couldn't see anything unusually. The installer worked fine on my old system, that is there were no changes to the script between the old and new computer (verified with git).
NOTE: the installer script and folders were located on a different drive on my old laptop.
Any ideas would be greatly appreciated.
2020-02-13 -13h32m09 873.png (98.16 KiB) Viewed 1745 times
Re: Unexpected Exception when opening project
Unfortunately, I can not say for sure why this happens.
In order for me to further investigate this, could you please forward me a copy of your .AIP file by e-mail at support at advancedinstaller dot com?
Did this issue start right after you updated your Windows from version 7 to 10?
