jasonhudgens1
ProgressBar with download size
Hello everybody
My installation includes various prerequisites that the user has to select. These are all downloaded via a URL link, so that the installation setup remains small.
My question is;
Is it possible to show at ProgressBar how much (Kb or Mb) has already been downloaded and how much is still open?
For example like this:
https://4.bp.blogspot.com/-Jd62SDbAdvk/ ... essBar.JPG
Re: ProgressBar with download size
Hello Jason,
To be fully honest with you, I am not sure that scenario is achievable, as the prerequisite is basically represented by a separate process.
However, you can try the method described in the following thread:
Update action text and progressbar with C#/DTF custom action
and see if that helps.
One note here (if you manage to make this work), most probably, the prerequisites must be added as a feature-based prerequisite, as the custom action is scheduled in the "Wizard Dialogs Stage" --> after "User Selection" action group.
Hope this helps somehow.
