LeisureTime
ExitDialog doesn't show
I am distributing my program via EXE, and it seems to work except the exit dialog doesn't show. The install just ends without giving notification to the user. That seems discourteous. Can someone tell me why my Exit Dialog isn't showing? Please see attached screenshots for my settings on the Dialogs page.
Thanks!
Re: ExitDialog doesn't show
Unfortunately, I can not say for sure why this happens.
In order for me to further investigate this, could you please forward me the following resources, by e-mail at support at advancedinstaller dot com:
- a copy of your .AIP file
- a download link for the setup (the .EXE file) built with the .AIP file
One really strange thing I could notice is the fact that the "PrepareDlg" (respectively "PreparePrereqDlg") dialogs are missing, which is not normal - you can't even delete them from the "Dialogs" page. Could you please let me know how did you delete those dialogs?
LeisureTime
Sent email this morning. Thanks!
Hello Ted,
First of all, please accept my apologies for the delayed reply, but we were quite busy lately.
The reason why your dialogs are not shown is because you have the "Limit to basic user interface (simple progress and error handling)" option checked in the "Install Parameters" page.
If you want your dialogs to be displayed, please uncheck that option and rebuild your project.
LeisureTime
I will try that. Thank you so much!
You are always welcome, Ted!
Hope that will help.
